Threads: 3
Thanks Received: 67 in 18 posts
Thanks Given: 2
Yeah OK but my issue is , as I said above , it will not let me put up two posts back to back , I can post the first one and come back ten minutes later and post again and if nobody ahs posted after the first post , it puts the second one in the first ..
JtB
Try adding again , one of the best looking shovels I have ever seen , but gimme a two piece steel fatbob tank
JtB
See what I mean , this is three posts in one box
So Many Highways
So Little Time
The following 3 users say Thank You to JacktheBagger for this post:
Threads: 22
Thanks Received: 239 in 77 posts
Thanks Given: 165
(11-07-2026, 03:55 PM)JacktheBagger Wrote: Yeah OK but my issue is , as I said above , it will not let me put up two posts back to back , I can post the first one and come back ten minutes later and post again and if nobody ahs posted after the first post , it puts the second one in the first ..
JtB
JtB
I think what is happening is on your first post, when your done writing the post you have to go to the bottom of the screen to post the reply.
Then you can do the same for the second, third, etc.
Your first post is not posting to the board. It's in your box when you go to post again 10 minutes later, but it didn't post to the board.
I'll try making 3 posts back to back to back and test it.
Lump
2025 "Blue Streak" CVO, 2008 APC "High Roller"
The following 2 users say Thank You to L2Lump for this post:
Threads: 22
Thanks Given: 165
Post Number 1
Lump
Threads: 22
Thanks Given: 165
Post 2
Lump
Threads: 22
Thanks Given: 165
Post 3
Lump
Threads: 22
Thanks Given: 165
JacktheBagger I think what you're doing on subsequent posts is hitting the "Reply" button, and not the "New Reply" button.
If you mouse over the "Reply" button you'll see it's quoting your other posts, but you want the New Reply button for back to back posts.
Lump
The following 3 users say Thank You to L2Lump for this post:
Threads: 3
Thanks Given: 2
Okay lets us see
this is one
JtB
This is two , I hit new reply to open the box
JtB
after hitting new reply and typing I then hit reply
JtB
and here we is
JtB
So Many Highways
So Little Time
The following 1 user says Thank You to JacktheBagger for this post:
Threads: 22
Thanks Given: 165
(11-07-2026, 06:41 PM)JacktheBagger Wrote: Okay lets us see
this is one
JtB
JtB
JtB
and here we is
JtB
One never posted to the board so the bottom of the page "Post reply" button was never pushed on one.
Lump
The following 1 user says Thank You to L2Lump for this post:
